Rank: Member
Hello Folks:
I am evaluating DMC to see if it will do what I need; which is the following:
I have DVDs I create in Avid Liquid that produce VOBs on my local hard-drive as well burn directly to DVD. The DVDs are created in NTSC format and I need to create DVD versions in PAL for viewers overseas, etc. So, ... my plan was to take the VOBs that were created in the directory VIDEO_TS (on my hard-drive) and convert them to PAL using DMC, and then burn them to DVD using Nero.
A typical VIDEO_TS folder will contain the following files: VIDEO_TS.BUP VIDEO_TS.IFO VIDEO_TS.VOB VTS_01_0.BUP VTS_01_0.IFO VTS_01_1.VOB VTS_01_2.VOB VTS_01_3.VOB
My plan was to create duplicate directory structure as above with VIDEO_TS on the root; except the VOBs will now be PAL instead of NTSC. Then I was going to burn the directory structure "VIDEO_TS" and everything under it to DVD.
Now, my questions are: 1) Does this seem like a feasible and consistent process?
2) After conversion, I noticed that the file extension is mpg as in "VTS_01_1.mpg" versus "VTS_01_1.VOB" Can I just change the extension after conversion?
3) Considering this scenario, do I need to burn via Nero as a "Data DVD" or "Video DVD?"
4) The other files under the VIDEO_TS directory don't have to be changed in anyway - right?
5) Are there any gotchas I may not be aware of?
Thanks in advance for your patience and help! Kevin
Digital Media Converter can convert your video from NTSC to PAL format.
Our recommended procedure for creating PAL DVDs would be:
1. Convert the VOB files to PAL MPEG 2 files (.mpg extension) as you have already done. 2. Use your own DVD burning program to create a new DVD using the Video DVD in PAL format. The program will create new BUP and IFO files which will match the video files.
