Parameters for PC for monitoring 6 cameras
lancer
Posted : Tuesday, August 19, 2014 9:20:20 AM(UTC)
Hello I need parameters for pc for 6-8 cameras which processor cores and how much RAM or whether it be a video card.
Posted : Sunday, January 18, 2015 5:03:17 PM(UTC)
Security Monitor Pro is relatively efficient with both CPU and RAM usage.
The CPU usage depends on the resolution being captured from your cameras. For a 640x480 capture with 8 cameras, a Core i3 with 4GB of RAM is sufficient and a Core i5 is recommended. If you are capturing higher resolution such as 1280x1024, I suggest using at least a Core i5 processor with 8GB of RAM.
You can use the evaluation version to test your cameras and CPU usage.
