Which cameras will work with Security Monitor Pro?
Makur
Posted : Thursday, October 22, 2015 7:00:41 PM(UTC)
I am looking to buy a network camera and I need some advice on which one would work best for me. I have researched around and have found a bunch that have outdoor enclosures, IR, and other features I need, but I am not sure which one would work with Security Monitor Pro. Can you help?
Posted : Thursday, October 22, 2015 11:01:13 PM(UTC)
Security Monitor Pro supports more than 300 different camera manufactures and over 2100 camera models.
You can check the supported cameras list:
https://www.deskshare.com/ip-cameras-manufacturers-models.aspx
gaz132
Posted : Saturday, December 5, 2015 8:43:21 PM(UTC)
I recommend Wanscam JW0011 for price and quality
records great to your pc using the Security Monitor Pro software
also works with apps on your phone
no need for an ip address
works anywhere
very secure
