Split recorded AVI file into 2 parts
watchdaride
Posted : Wednesday, March 29, 2006 1:25:31 PM(UTC)
I did some recordings that is more than 600mb to fit on a disc. Do you know of a program or way to divide it to 2 file so that it would fit on a disc? The recording siz was 984x648 for 64 minutes .
Posted : Friday, March 31, 2006 4:25:00 AM(UTC)
Since you have already recorded the file, you can use Digital Media Converter by DeskShare to split the file. You can also convert the file to almost all popular formats. For more information on Digital Media Converter, visit:
https://www.deskshare.com/audio-video-converter.aspx
Another option is that you can start using My Screen Recorder Pro for any recordings you do in the future. The Pro version can automatically segment the file to pre-defined sizes. The segmenting option is available from Tools ] Settings ] File segments.
