Hi,
I'd like to use your software with analog cameras via 'some' type of input converter.
I found the 'hauppauge 188' pci card; is this type of device compatible, and further, might you be able to suggest an analog converter?
For just one camera, it seems everyone offers some new version of the USB 'grabbee', composite/s-video in, but I'm leary of this $20 input. Is there a product (or avenue you can suggest) you can recommend that would get a 540-line CCTV camera signal into the computer with good quality?
thanks in advance!
