I was able to set up my system so that Digital Media Converter could convert DVR-MS files, but two things are preventing me from getting acceptable quality conversions:
1) I can't find an option to do two-pass (VBR) encoding. Using a constant bit rate, the quality varies according to the scene, which means the video is extremely blocky whenever there is any significant motion. I would be happy with VBR in either WMV or MPEG 4 formats.
2) I can't seem to actually adjust any of the settings for XviD or DivX encoding. This one is particularly frustrating since the settings do appear under Settings:Properties, but the Keyframe and Quality sliders are locked.
Thanks in advance for any help you can provide.
