Using a IR CCTV camera with a USB capture device
Multistud
Posted : Saturday, August 10, 2013 2:52:34 PM(UTC)
Multistud
Will your WebCam Monitor work with a IR security camera connected to a usb s video and composite video capture cable? I want to hook a IR security camera to my computer and detect motion.
Posted : Wednesday, September 18, 2013 9:30:31 AM(UTC)
Yes, WebCam Monitor will recognize most USB capture devices. You may need to load the latest drivers for the capture device.
Make sure the capture device is connected and click on the add camera button. Select the USB capture from the list and you should see video from your CCTV camera.
