You can configure your PC to restart after a power failure from your BIOS settings. After Windows is reloaded, use the software 'TweakUI' to log in automatically. In Security Monitor Pro, click Tools > Application Settings > General. Check the box for ' When Windows starts, launch Security Monitor Pro'. I also suggest selecting the box for ' When Security Monitor Pro launches, restart the previously running actions'. This procedure will recover your monitoring after a power loss or power cycle.
