Hello, I have been using Video Edit Magic for about 6 months, and I have seen that it has fairly significant capability.
Recently, I have been finishing up a project (about 15 minutes long). I opened this project, and started to play it. There was no audio, despite my audio tracks being turned to their appropriate volumes. Then I tried opening several other projects to see if their audio would play. None of my projects will play their audio anymore.
I can't figure out what has happened! My speakers are plugged in and turned on, the volume is turned all the way up, and yet I hear no audio!
This started to occur after I had a failure with a different project (the project involved a rather long gif file). After several crashes, I managed to get a movie of the gif made. It was after this that my other projects had no audio, perhaps this has something to do with the audio failure.
Any help you can give would be greatly appreciated.
